vba코드 관련하여 문의드립니다.
우선 이전 다른 사용자분께서 만들어놓은 코드인데요..
Sub OpenfrmCustomer()
icfactory.Show
Sub update()
Dim A As Double
Dim i, j, k As Integer
Dim rng As Range
j = 0
k = 0
Sheets("Main").Select
Range("A1").Select
ActiveCell.FormulaR1C1 = "1"
If Application.WorksheetFunction.CountA(Worksheets("Main").Range("F:F")) > 1 Then
Range("A1").Select
Selection.Copy
Sheets("Date").Select
Range("G2").Select
Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlMultiply, _
SkipBlanks:=False, Transpose:=False
Selection.NumberFormatLocal = "0"
If Application.WorksheetFunction.CountA(Worksheets("in").Range("A:A")) > 1 Then
Range("A1").Select
Selection.Copy
Sheets("in").Select
Range("G2").Select
If Application.WorksheetFunction.CountA(Worksheets("Out").Range("A:A")) > 1 Then
Range("A1").Select
Selection.Copy
Sheets("Out").Select
Range("G2").Select
If Application.WorksheetFunction.CountA(Worksheets("Item Master").Range("A:A")) > 1 Then
Range("A1").Select
Selection.Copy
Sheets("Item Master").Select
Range("B2").Select
Range("A1").Select
Selection.Clear
'1. Date 시트에 없는 in 시트 상품 가져오기
For i = 1 To Application.WorksheetFunction.CountA(Worksheets("in").Range("A:A")) - 1
Sheets("in").Select
Range("G2").Select
Selection.Copy
Range("A:L").Select
With Selection.Font
.ThemeColor = xlThemeColorLight1
.TintAndShade = 0
Columns("G:G").Select
If Application.WorksheetFunction.IfError(Application.VLookup(Worksheets("in").Range("G" & i + 1).Value, _
Worksheets("Date").Range("G:G"), 1, False), "O") = "O" Then
Worksheets("Item Master").Range("B:B"), 1, False), "O") <> "O" Then
A = Worksheets("in").Range("G" & i + 1).Text
Sheets("in").Select
Range("G:G").Select
Selection.Find(What:=A, After:=ActiveCell, LookIn:= _
xlFormulas, LookAt:=xlPart, SearchOrder:=xlByRows, SearchDirection:= _
xlNext, MatchCase:=False, MatchByte:=False, SearchFormat:=False).Select
Range(Selection.Offset(0, -6), Selection.Offset(0, 5)).Select
Range(Selection, Selection.End(xlToRight)).Copy
Range("A1").Select
Selection.End(xlDown).Select
ActiveCell.Offset(1, 0).Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
With Selection.Font
.Color = -4165632
.TintAndShade = 0
j = j + 1
'2. Date 시트에 있는 Out 시트 상품 삭제하기
For i = 1 To Application.WorksheetFunction.CountA(Worksheets("Out").Range("A:A")) - 1
Range("G" & i + 1).Select
Selection.Copy
If Application.WorksheetFunction.IfError(Application.VLookup(Worksheets("Out").Range("G" & i + 1).Value, _
Worksheets("Date").Range("G:G"), 1, False), "O") <> "O" Then
A = Worksheets("Out").Range("G" & i + 1).Text
Sheets("Date").Range("G2:G" & Application.WorksheetFunction.CountA(Worksheets("Date").Range("A:A")) - 1).Select
Selection.Delete Shift:=xlUp
k = k + 1
Sheets("in").Select
Columns("G:G").EntireColumn.AutoFit
Range("A1").Select
Range("A1").Select
Range("A1").Select
'3. Main 시트에 Date에 있는 상품 리스트 가져오기
If Application.WorksheetFunction.CountA(Worksheets("Date").Range("A:A")) > 1 Then
For i = 1 To Application.WorksheetFunction.CountA(Worksheets("Date").Range("A:A")) - 1
A = Worksheets("Date").Range("G" & i + 1).Text
If Application.WorksheetFunction.IfError(Application.VLookup(Worksheets("Date").Range("G" & i + 1).Value, _
Range("B:B").Select
Range(Selection, Selection.Offset(0, 6)).Select
Selection.Copy
Range("F" & i + 6).Select
ActiveCell.Offset(0, 7).Value = Application.VLookup(Worksheets("Date").Range("G" & i + 1).Value, _
Worksheets("Date").Range("G:H"), 2, False)
Range("a1").Select
Columns("H:H").Select
Selection.Copy
Columns("M:M").Select
Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
Range("M6").Select
ActiveCell.FormulaR1C1 = "QTY"
Range("A1").Select
Columns("A:L").Select
With Selection
.HorizontalAlignment = xlLeft
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
With Selection
.VerticalAlignment = xlCenter
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = False
Columns("F:F").Select
Columns("F:F").EntireColumn.AutoFit
Range("L4") = Application.WorksheetFunction.Sum(Worksheets("Main").Range("m:m"))
Range("A1").Select
MsgBox "In 시트 " & j & "개 추가, Out 시트 " & k & "개 삭제하였습니다."
현재 이 코드이고 화면은 첨부1 이미지 처럼 기존에는 Product name칸이 없었습니다. 그런데 해당칸을 삽입하고 난뒤에 업데이트 누르니 첨부2 처럼 틀어졌는데요.. 제가 해당칸을 늘릴때는 vba언어 사용하지 않고 함수 vlookup을 사용했습니다...
혹시 코드를 어떻게 수정을 해야 흐트러지지 않을까요 ???
2022.07.31 | 7 | 842 | ||
2022.08.04
추천 3
조회 64
2022.08.04 | 3 | 64 |
(87)
추천 116
조회 5957
2021.10.28 | 116 | 5957 |
40987 | VBA |
New 선택한 셀 근처에 차트 나타내기
2022.08.08 | - | 23 |
40982 | VBA |
New 입력 수량에 따른 버튼 또는 레이블 생성
2022.08.08 | -2 | 22 |
40974 | 함수/공식 |
2022.08.08 | - | 37 |
40971 | 기능/도구 |
New 이름 정의 범위 선택시 에러 발생
2022.08.08 | - | 36 |
40966 | 함수/공식 |
(8)
2022.08.08 | - | 41 |
40963 | 함수/공식 |
2022.08.08 | - | 33 |
40961 | 기능/도구 |
2022.08.08 | - | 28 |
40960 | 기능/도구 |
2022.08.08 | - | 19 |
40958 | 차트/그래프 |
New 그래프 가로 축 레이블 설정 부분
2022.08.08 | - | 29 |
40955 | 함수/공식 |
2022.08.08 | - | 44 |
40953 | 함수/공식 |
2022.08.07 | - | 34 |
40952 | 문서서식 |
2022.08.07 | - | 30 |
40945 | VBA |
2022.08.07 | - | 56 |
40937 | 파워쿼리/피벗 |
New 시트별로 열이 다른 경우 시트를 통합하는 방법
2022.08.07 | - | 37 |
40936 | VBA |
New 달력 유저폼 실행위치관련 질문
2022.08.07 | 1 | 46 |
40921 | 함수/공식 |
2022.08.06 | - | 47 |
40916 | 문서서식 |
New 이동옵션에서 상수와 수식
2022.08.06 | - | 50 |
40915 | 문서서식 |
New 셀 서식 중 "월", 월 차이
2022.08.06 | 1 | 47 |
40912 | 함수/공식 |
New IF 조건문이 잘 되지 않습니다.
2022.08.06 | - | 44 |
40908 | VBA |
New 매월 초 100개의 파일을 100개의 거래처로 메일 보내는 방법 문의
2022.08.06 | - | 56 |
40906 | 기능/도구 |
New 시트 이동복사 했는데 똑같이 보여지지 않아요
2022.08.06 | 1 | 45 |
40904 | 문서서식 |
New 4명의 일일실적을 월별 총합으로 보기좋게 작성할 수 있을까요?
2022.08.06 | - | 46 |
40903 | 함수/공식 |
New =YahooFinanceHistory( )사용방법 문의
2022.08.06 | - | 36 |
40902 | VBA |
New Page_Setup에서 codename 전달
2022.08.05 | - | 33 |
40898 | 함수/공식 |
New 함수 해석좀...
2022.08.05 | - | 45 |
40896 | 함수/공식 |
New 고급11강- 필터 함수 공부중 입니다
2022.08.05 | - | 39 |
40895 | VBA |
New Get_DB 전체 행이 불러와지지 않습니다
2022.08.05 | - | 37 |
40892 | 기능/도구 |
New 엑셀 셀에 달력 넣기
2022.08.05 | - | 41 |
40889 | 함수/공식 |
New 엑셀 여러열 일치하는 값 대입
2022.08.05 | - | 46 |
40887 | VBA |
New vba combobox에 목록이 처음 들어 갔을 때 안 떠요
2022.08.05 | - | 27 |
