행렬 변환 VBA 관련질문
H.B
수염그래프를 만들기위해 종을 횡으로 데이터 변환(Transpose)을 하도록 제 나름대로 vba를 작성해봤습니다(하기)
하지만, 한 횡에 데이터가 많고, 6개 부분을 나눠서 하나하나 변환하도록 만드니 너무 실행에 시간이 걸리네요....
혹시 한 횡의 여러 부분을 한번에 변환할수 있게(offset등을 써서??) 할수는 없을까요?
도움 부탁드립니다.
작성 vba 첨부파일 및 하기 참고
For i = lng To 5 Step -1
Range(Rows(i + 1), Rows(i + 1).Offset(3)).Insert Shift:=xlDown ' 4개 행 삽입
' +각 노란색 행부분을 행렬전환하여 넣은다음 불필요한 원래 열부분 데이터제거
Range(Cells(i, 4), Cells(i + 4, 4)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 4), Cells(i, 4 + 4)).Value)
Range(Cells(i, 1 + 4), Cells(i, 4 + 4)).ClearContents
Range(Cells(i, 9), Cells(i + 4, 9)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 9), Cells(i, 4 + 9)).Value)
Range(Cells(i, 1 + 9), Cells(i, 4 + 9)).ClearContents
Range(Cells(i, 14), Cells(i + 4, 14)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 14), Cells(i, 4 + 14)).Value)
Range(Cells(i, 1 + 14), Cells(i, 4 + 14)).ClearContents
Range(Cells(i, 19), Cells(i + 4, 19)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 19), Cells(i, 4 + 19)).Value)
Range(Cells(i, 1 + 19), Cells(i, 4 + 19)).ClearContents
Range(Cells(i, 24), Cells(i + 4, 24)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 24), Cells(i, 4 + 24)).Value)
Range(Cells(i, 1 + 24), Cells(i, 4 + 24)).ClearContents
Range(Cells(i, 29), Cells(i + 4, 29)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 29), Cells(i, 4 + 29)).Value)
Range(Cells(i, 1 + 29), Cells(i, 4 + 29)).ClearContents
Range(Cells(i, 34), Cells(i + 4, 34)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 34), Cells(i, 4 + 34)).Value)
Range(Cells(i, 1 + 34), Cells(i, 4 + 34)).ClearContents
Range(Cells(i, 39), Cells(i + 4, 39)).Value = Application.WorksheetFunction.Transpose(Range(Cells(i, 39), Cells(i, 4 + 39)).Value)
Range(Cells(i, 1 + 39), Cells(i, 4 + 39)).ClearContents
'A~C열의 공통값 삽입된행 붙여넣기
Range(Cells(i + 1, 1), Cells(i + 4, 3)).Value = Range(Cells(i, 1), Cells(i, 3)).Value
  • 2021-11-08 16:54
    처리 시간은 구형 삼성 RC420에서 약 5초 걸립니다.
    아래 Coding과 사진 및 첨부 파일 참조하세요.
    Sub myTranspose()
    Dim myRng, myArr1, myArr2 As Variant
    Dim i, n, k, m, rcCount As Long
    Set myRng = Range("D5:H2662")
    myArr1 = myRng.Value
    rcCount = UBound(myArr1, 1) * UBound(myArr1, 2)
    ReDim myArr2(1 To rcCount) As Variant
    k = 1
    For i = 1 To UBound(myArr1, 1)
    For n = 1 To 5
    myArr2(k) = myArr1(i, n)
    k = k + 1
    For m = 1 To UBound(myArr2)
    Range(Cells(m + 4, 3), Cells(m + 4, 3)).Value = myArr2(m)
    첨부파일 : 문의사항_답변.xlsm
  • 2021-11-08 18:35
    대단히 감사합니다.
    아, 정말 죄송합니다만 yukon님 그 제가원한건 노란색열을 하나로 합치는 게 아니라 상기그림처럼 각 노란색 영역에 붙여넣는거여서요 ㅠ 써주신 구문중 redim의 의미를 잘모르겠습니다만, 각 노란색 영역마다 행을 5개씩 삽입한후, 종으로 되있는 데이터를 횡으로 노란색 행에 삽입하는 방법이 없을까요.
  • 2021-11-08 19:27
    아 코드읽어보면서 대략적으로 이해했습니다 동일작업을 수회 반복하면 되겠군요 ㅎ 감사합니다. 나름대로 조금 변형해서 만들어보도록 하겠습니다.
전체 4,670
트로피 오빠두엑셀 2021.10.28 16 743
New 0이상의 값(유효값)이 있는 칼럼과 그 값을 불러오고 싶습니다. 첨부파일
크놉스 | 11:41 | 추천 0 | 조회 3
크놉스 11:41 0 3
New 엑셀 차트에서 특정 값이 너무 높을때 차트화 하는 법
담담 | 11:36 | 추천 0 | 조회 5
담담 11:36 0 5
New vba 코딩을 부탁드립니다. 첨부파일
Trimman | 11:09 | 추천 -1 | 조회 11
Trimman 11:09 -1 11
지천 | 10:12 | 추천 0 | 조회 16
지천 10:12 0 16
유령회원 | 08:30 | 추천 0 | 조회 15
유령회원 08:30 0 15
엑셀이 | 00:19 | 추천 0 | 조회 16
엑셀이 00:19 0 16
하늘의 꿈 | 2021.12.01 | 추천 0 | 조회 19
하늘의 꿈 2021.12.01 0 19
seorin 2021.12.01 0 18
김학동 2021.12.01 0 19
마른막대기 | 2021.12.01 | 추천 0 | 조회 27
마른막대기 2021.12.01 0 27
24207 함수/공식
New 중복값 중 제일 마지막 값 추출 (2)
rladud99 2021.12.01 0 34
24203 함수/공식
이시현 2021.12.01 0 33
24200 함수/공식
wlfl**** 2021.12.01 0 43
24191 함수/공식
노랑토끼 2021.12.01 0 51
24188 VBA
24184 문서서식
New 엑셀 자동채우기 관련 문의 (1) 답변완료
오문환 | 2021.12.01 | 추천 0 | 조회 39
오문환 2021.12.01 0 39
24182 함수/공식
New 줄바꿈 함수 도와주세요 첨부파일 (3)
김상준 2021.12.01 1 40
FLOWERBALL 2021.11.30 0 46
ryan_cruze 2021.11.30 0 42
최강씨맨 2021.11.30 0 34
PAKSAW | 2021.11.30 | 추천 0 | 조회 48
PAKSAW 2021.11.30 0 48
ㄱ박민극 2021.11.30 -1 45
24154 피벗테이블
가리 2021.11.30 0 37
24153 VBA
New 엑셀 검색 창 첨부파일 (2)
이혜 2021.11.30 0 36
24148 피벗테이블
New 피벗테이블 형태의 데이터베이스 변환 (1)
이길호 2021.11.30 0 32
파워쿼리/피벗
New Re:피벗테이블 형태의 데이터베이스 변환
Yukon 2021.11.30 0 22
24140 VBA
이치영 2021.11.30 0 44
24135 VBA
툴잇지 with 우정기기 2021.11.29 0 59
24132 함수/공식
키큰아저씨 2021.11.29 0 58
24129 VBA
New 직사각형 도형 삭제vba (2) 답변완료
H.B 2021.11.29 1 35
24126 VBA
볼펜수리공 2021.11.29 0 35
